Error on "when CLIENT_ACCEPTED" IRule
Hello,
I created the following Irule in order to increase the TCP idle TimeOut for certain applications. When a connexion occur, in /var/log/ltm file I see systematically the following error and it dosen’t work properly:
Sep 5 15:42:11 F5-Prod err tmm[7623]: 01220001:3: TCL error: /Common/IR_TCP_TimeOut - no serverside connection established (line 1) invoked from within “TCP::server_port” (“1423” arm line 4) invoked from within "switch [TCP::local_port] { 1423 { …
Even so my IRule is very simple :
when CLIENT_ACCEPTED {
1423 {
set idle 3600
IP::idle_timeout 3600
default {
set idle 300
IP::idle_timeout 300
when SERVER_CONNECTED {
IP::idle_timeout $idle }
Do you have some idea? Thank you
i do not see TCP::server_port in the irule. is it complete irule?
Yes this is the complete IRule.
I get the example here: DevCentral - An F5 Technical Community
When I replace “switch [TCP::local_port]” by “switch [TCP::server_port]” it doesn’t work as well.
why do you want to change TCP::local_port to TCP::server_port? TCP::local_port is destination port on clientside connection (between client and bigip).
It was just a test, because I don’t really understand why there is an error.
I suspected a bug with TCP::local_port …
i did not get an error.
config
[root@ve11a:Active:In Sync] config  tmsh list ltm rule qux
ltm rule qux {
  log local0. ""
    1423 {
      set idle 3600
    default {
      set idle 300
  log local0. ""
 /var/log/ltm
[root@ve11a:Active:In Sync] config  tail -f /var/log/ltm
Sep  5 08:27:39 ve11a info tmm[15094]: Rule /Common/qux CLIENT_ACCEPTED:
Sep  5 08:27:39 ve11a info tmm[15094]: Rule /Common/qux SERVER_CONNECTED:
So no bug :-), but the problem still there. When a connexion occur with port 1423 there is the following error:
I have built the following simple IRule. It’s working fine but the timeout is increased for all flows (no filter on port).
set the TCP idle timeout for the client to 3600
set the TCP idle timeout for the server to 3600
Hello,
The error occurs because the BIG-IP receive some UDP traffic. The script does not managed UDP port. so a filter must be added at the start of the script.
