Problem this snippet solves:
The script you need for this task must:
- Identify the Enterprise Manager system on which you wish to initiate the delete devices process, specifying username and password as needed.
- Specify the device address(es) that you wish to delete.
- Initialize the API.
- Run the API.
How to use this snippet:
To delete devices:
- Create a script similar to the code sample shown below.
- From a command prompt, run your script.
- When the code finishes running, all associated configuration information for the specified devices (such as alerts, certificate information, and device archives) are removed from the Enterprise Manager database.
Code :
* A class for testing the Management::EM::delete_devices iControl interface.
public class ManagementEMDeleteDevices {
private static int MIN_ARGS = 3;
private static String USAGE =
"ManagementEMDeleteDevices <em address=""> <em username=""> <em password=""> " +
"[<device address="">] ...";
private static int EM_PORT = 443;
* The main method.
* @param args command line arguments
public static void main(String[] args) {
if (args.length < MIN_ARGS) {
System.err.println("Usage: " + USAGE);
System.exit(1);
String emAddress = args[0];
String emUsername = args[1];
String emPassword = args[2];
String[] deviceAddresses = new String[args.length - MIN_ARGS];
for (int i = 0; i < deviceAddresses.length; i++) {
deviceAddresses[i] = args[i + MIN_ARGS];
try {
iControl.Interfaces ic = new iControl.Interfaces();
ic.initialize(emAddress, EM_PORT, emUsername, emPassword);
ic.getManagementEM().delete_devices(deviceAddresses);
catch (Exception e) {
System.err.println("Failed to delete devices: " + e.getMessage());
System.exit(1);
System.out.println("Device(s) deleted");
} // public static void main
} // public class ManagementEMDeleteDevices</device></em></em></em>
