Wanted to share the below method for deleting AS3 tenant’s as it wasn’t documented . You can use the HTTP delete method; but if an admin misses the tenant name after /declare/ it would wipe out all tenants!
If you POST the below body to the ‘https://{{bigip_mgmt}}/mgmt/shared/appsvcs/declare’; as its a blank declaration; AS3 will remove your partition / tenant.
"class": "AS3",
"action": "deploy",
"declaration": {
"class": "ADC",
"schemaVersion": "3.1.0",
"id": "tenant_name",
"label": "tenant_name_via_AS3",
"remark": "tenant_name_via_AS3",
"CHANGE-ME-TO-TENANT-NAME": {
"class": "Tenant"
