Delete Device (Java code sample)
Problem this snippet solves:
This Java client code sample uses Enterprise Manager’s device inventory to delete a list of devices managed by the referenced Enterprise Manager.
Code :
 * A class for testing the Management::EM::delete_devices iControl interface.
public class ManagementEMDeleteDevices {
    private static int MIN_ARGS = 3;
    private static String USAGE =
        "ManagementEMDeleteDevices <em address=""> <em username=""> <em password=""> " +
        "[<device address="">] ...";
    private static int EM_PORT = 443;
     * The main method.
     * @param args command line arguments
    public static void main(String[] args) {
        if (args.length < MIN_ARGS) {
            System.err.println("Usage: " + USAGE);
            System.exit(1);
        String emAddress = args[0];
        String emUsername = args[1];
        String emPassword = args[2];
        String[] deviceAddresses = new String[args.length - MIN_ARGS];
        for (int i = 0; i < deviceAddresses.length; i++) {
            deviceAddresses[i] = args[i + MIN_ARGS];
        try {
            iControl.Interfaces ic = new iControl.Interfaces();
            ic.initialize(emAddress, EM_PORT, emUsername, emPassword);
            ic.getManagementEM().delete_devices(deviceAddresses);
        catch (Exception e) {
            System.err.println("Failed to delete devices: " + e.getMessage());
            System.exit(1);
        System.out.println("Device(s) deleted");
    } // public static void main
} // public class ManagementEMDeleteDevices</device></em></em></em>
