If making a typo using the modify /net tmsh command like this:
modify /net interface 1/1.1 nedia 10000SR-FD
It creates a new interface called “nedia” with status “pend”. How does one delete this interface?
it was gone after i restarted tmm. i could not find another method to get rid of it. :-/
I’ve rebooted the entire Viprion chassis multiple times and still can’t get rid of it.
This relates to VE but as this is VIPRION perhaps it might help;
[tmsh] stop sys services all
rm /var/db/mcpd*
touch /service/mcpd/forceload
shutdown -r now
steven is correct. this is tracked as ID248742.
ID248742 - CLI allows accidental creation of pending interfaces too easily
root@(VIP4400-R70-S37)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) show net interface nedia
Net::Interface
Name Status Bits Bits Pkts Pkts Drops Errs Media
In Out In Out
nedia pend 0 0 0 0 0 0 none
root@(VIP4400-R70-S37)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list net interface nedia
net interface nedia {
if-index 896
root@(VIP4400-R70-S37)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) q
[root@VIP4400-R70-S37:/S1-green-P:Active:Standalone] config
[root@VIP4400-R70-S37:/S1-green-P:Active:Standalone] config clsh rm -rf /var/db/mcpdb.*
=== slot 2 addr 127.3.0.2 color red ===
=== slot 3 addr 127.3.0.3 color red ===
=== slot 4 addr 127.3.0.4 color red ===
=== slot 1 addr 127.3.0.1 color green ===
[root@VIP4400-R70-S37:/S1-green-P:Active:Standalone] config clsh bigstart restart
01020036:3: The requested interface (nedia) was not found.
Yeah, I had tried deleting the /var/db/mcpd* files but no luck there.
sol13468 finally pointed me to a working solution:
OK, great you got it fixed.
