I have configured SSL client profile in LTM which is working fine. I would now like to add CRLDP authentication using HTTP URL in client certificate.
Is that supported with LTM ? I see a fix (ID 325296) in v11.4.1HF2 which adds this functionality but it is under APM.
Also, do I have to configure a specific CRLDP configuration for this or can I just use the default “ssl_crldp” profile? (after all, I would like F5 to simply use HTTP URL supplied in the certificate)
