thanks, it seems to be in run state.
i have rebooted and see the below errors.
Jul 15 00:26:58 f5-labinfo mprov:11127:: ‘There are NO extra disks.’
Jul 15 00:26:58 f5-laberr mprov:11127:: ‘Disk limit exceeded. 20088 MB are required to provision these modules, but only 7384 MB are available.’
Jul 15 00:26:58 f5-labinfo mprov:11127:: ‘Provisioning (validation) failed.’
Jul 15 00:26:58 f5-laberr mcpd[9439]: 01071008:3: Provisioning failed with error 1 - ‘Disk limit exceeded. 20088 MB are required to provision these modules, but only 7384 MB are available.’ .
Jul 15 00:26:58 f5-labemerg load_config_files: “/usr/bin/tmsh -n -g load sys config partitions all” - failed. -- Loading schema version: 11.5.1 Loading schema version: 11.6.5.2 01071008:3: Provisioning failed with error 1 - ‘Disk limit exceeded. 20088 MB are required to provision these modules, but only 7384 MB are available.’ . Unexpected Error: Loading configuration process failed.
Jul 15 00:26:58 f5-laberr tmsh[11042]: 01420006:3: Loading configuration process failed.
Jul 15 00:26:59 f5-laberr mcpd[9439]: 01070425:3: Full configuration load failed.
Jul 15 00:26:59 f5-labinfo promptstatusd[6329]: 01460007:6: semaphore mcpd.running(1) released
Jul 15 00:26:59 f5-labnotice promptstatusd[6329]: 01460006:5: mcpd.running(1) released, subscribe to mcpd
A check on disk properties show me the following.
list /sys disk logical-disk HD1 all-properties
sys disk logical-disk HD1 {
mode mixed
size 81920
vg-free 3484
vg-in-use 78228
vg-reserved 0
The error says “Provisioning failed with error 1 - ‘Disk limit exceeded. 20088 MB are required to provision these modules, but only 7384 MB are available.’” about disk space. But i am not confident on how to identify which disk or vg- is it referring to,i can’t see any 7384MB in disk outputs.
Please assist.
