Error post F5 upgrade
We’re in middle of F5 upgrade. This is the first time I am doing the upgrade.
We followed all the steps. Device came back after the reboot, but when I am logging into the device, it is giving me error as ‘The configuration has not yet loaded. If this message persists, it may indicate a configuration problem’.
On the other line, I am trying to reach TAC. During checking F5 articles, I came across this community so registered here to ask the question. Is anyone can help me with this pls?
@raj_raut - your post was held in moderation for a while. Your best bet is still probably connecting with Support.
If you have a ticket already that’s good, but if you are still waiting to hear back you may find some guidance here on DevCentral (which may also help clarify a few basic questions for Support and result in a quicker resolution)
Provide more detail about your question here (don’t share private/secure info)?
Support is certainly the best path to remain on the safe side.  If you like, you can run the following from a console to potentially call out the reason for the configuration not loading:
tmsh load sys config verify [partitions all]
Once the command completes the integrity check, with any luck you’ll see an error in the standard output listed similar to below:
01071922:3: Policy ‘/Common/http-to-https-redirect_policy’, rule ‘http-to-https_rule’; Error in Tcl expression: ‘undefined procedure: HTTP:uri: HTTP:uri’.
Unexpected Error: Validating configuration process failed.
In the above error, you’ll see the system has identified a syntax error in a LTM Policy object called “http-to-https-redirect_policy” where HTTP:uri is listed and HTTP::uri is the proper syntax.  In this example, there was no protection to keep you from making this mistake in the prior version, but there is now.  This is why it failed directly after the upgrade.
In addition, there may be warnings within this output, which are just an FYI at that juncture.  It will show you what has been deprecated in the new version that simply existed in the prior version.
If you are feeling ambitious, you can make a copy of the .conf file containing the object, manually update the error in the file itself, then load/save the configuration.  Again, this would only be recommended if you have a good understanding of the products and the potential hazards in manually editing anything.
As a best practice, it is always good to run the “tmsh load sys config verify” command PRIOR to an upgrade to make sure the integrity of your configuration files at least matches the schema for the version you’re currently running.  It won’t predict anything changing in the new version, hence the errors and warnings.
Reference: myF5
I hope that helps!
Hi @raj_raut qq, may I ask whether you reactivated the license prior to performing the upgrade?
If not, I would recommend you reactivate the license and take a reboot of the instance. You might be facing this issue due to Service Date Problem.
If the service check date is missing or is earlier than the license check date, the system will fail to load the configuration when you attempt to boot the upgraded software. If you boot into your newly upgraded system and the configuration fails to load due to a service check date issue, you can resolve this by reactivating your license.
Also, I agree with @LiefZimmerman , that you should contact Support for assistance in such situations. That said, the DevCentral Community is always available to help with any questions or clarifications you may have. I hope your issue has already been resolved by now.
Hope it helps!
Mayur
Thank you, Lief, Cory, and Mayur, for your thoughtful responses. I truly appreciate the support, and I am pleasantly surprised by the level of engagement. I’m happy to confirm that the issue has been resolved.
It was related to license reactivation, and here, I am seeing one of the suggestions to reactivate the license.
Thank you once again for your assistance.
We mostly contact the support always, but yesterday’s case was panic, so we were checking all the possible options. Good part is, I learnt new things and also, I came across Decentral Community.
Best, Raj
excellent outcome. Thanks @raj_raut   - I will take the liberty of marking the closest reply as the solution to help out anyone else down the line.
cheers and welcome!
