Hi - I am trying to combine two iRules on 9.x.
I believe a switch -glob statement would be appropriate, but not sure how do it with two different HTTP::‘operators.’
if { !([HTTP::path] equals “http://test/niku/app ”) } {
HTTP::redirect “https://test.testmarketing.com [HTTP::uri]”
if { [HTTP::host] equals “test” } {
Suggestions?
Thanks!
-TJ
I am not sure I follow completely, but it seems to me that this would do the trick:
if { ([HTTP::host] equals "test") & (!([HTTP::uri] equals "/niku/app")) } {
HTTP::redirect "https://test.testmarketing.com[HTTP::uri]"
nitass
September 15, 2011, 4:43pm
4
i think the 2nd HTTP_REQUEST is superset of the 1st one.
I read the request as “I want to redirect all traffic to this host, except for this one path”
nitass
September 15, 2011, 5:02pm
6
thanks. i overlooked not (!) in the question.
Sorry for the confusion guys. Let me update some words so that it doesn’t supersede itself.
Brain - I have always wanted some explanation to ‘&&’. This is an ‘or’ statement correct, not an ‘and’ statement, correct?
I’m looking for an ‘OR’
if { ([HTTP::host] equals “nice”) && (!([HTTP::uri] equals “/niku/app”)) } {
HTTP::redirect “https://nice.testmarketing.com [HTTP::uri]”
Thanks!
-TJ
nitass
September 15, 2011, 5:12pm
8
pls feel free to revise.
[root@orchid:Active] config b virtual bar80 list
virtual bar80 {
snat automap
pool foo80
destination 172.28.17.88:http
ip protocol tcp
rules myrule
profiles
http
tcp
[root@orchid:Active] config b rule myrule list
rule myrule {
if {[string tolower [HTTP::host]] equals "nice" and [string tolower [HTTP::uri]] ne "/niku/app"} {
HTTP::redirect "https://nice.testmarketing.com[HTTP::uri]"
[root@orchid:Active] config curl -I http://nice/niku/app
HTTP/1.1 404 Not Found
Date: Thu, 15 Sep 2011 17:12:10 GMT
Server: Apache/2.0.59 (rPath)
Vary: Accept-Encoding
Content-Type: text/html; charset=iso-8859-1
[root@orchid:Active] config curl -I http://nice/abc
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Brian - I have always wanted some explanation to ‘&&’. This is an ‘or’ statement correct, not an ‘and’ statement, correct?
The && is an AND statement and || is an OR statement. If you use an OR the above example, a person going to nice/niku/app will get redirected since it evaluated the left side first.
Thanks for your help guys. Much appreciated!
-TJ
