I am seeking suggestions on how best to handle a batch of commands for LTM. For example, if there is an existing route domain, whats the best way to add another VLAN?
There are several steps required: - Associate the VLAN to the existing RD - Create IPv4 self IPs on each cluster member - Create a floating IPv4 IP for the VLAN - Create IPv6 self IPs on each cluster member - Create a floating IPv6 IP for the VLAN
We have our own home brew automation tool that we’re incorporating into this design, so we’d prefer not to rely on middleware for managing configuration transactions. This is a distributed application, so many processes may be modifying the configuration simultaneously on the same device.
My questions in summary are: - Whats the best way to send this batch of commands? Execute each one separately then validate individually after each REST call? - If there is an error in any step, what’s the best path? Error out? Roll back? If that’s the case, what would be the best way to do so? - Is there a “check point” that can be configured or a way to treat the batch of commands as a total transaction that gets rolled back upon failure?
Any suggestions would be appreciated!
