AUTH::resposne_data
I have an SSL Cert and am using CRLDP on an LDAP server to accept/reject the cert based on revocation. However, I cannot grab the AUTH::response_data. Below is the irule:
when CLIENT_ACCEPTED {
set tmm_auth_ssl_crldp_sid 0
set tmm_auth_ssl_crldp_done 0
when CLIENTSSL_CLIENTCERT {
if {$tmm_auth_ssl_crldp_sid == 0} {
set tmm_auth_ssl_crldp_sid [AUTH::start pam default_ssl_crldp]
if {[info exists tmm_auth_subscription]} {
AUTH::subscribe $tmm_auth_ssl_crldp_sid
log local0. “Subscribing $tmm_auth_subscription”
AUTH::cert_credential $tmm_auth_ssl_crldp_sid [SSL::cert 0] AUTH::cert_issuer_credential $tmm_auth_ssl_crldp_sid [SSL::cert issuer 0] AUTH::authenticate $tmm_auth_ssl_crldp_sid
set tmm_auth_subscription [AUTH::subscribe $tmm_auth_ssl_crldp_sid]
log local0. “$Authenticating cert with crldp ID: $tmm_auth_ssl_crldp_sid”
log local0. “$tmm_auth_subscription”
SSL::handshake hold
when CLIENTSSL_HANDSHAKE {
set tmm_auth_ssl_crldp_done 1
when AUTH_RESULT {
if {[info exists tmm_auth_ssl_crldp_sid] and \
($tmm_auth_ssl_crldp_sid == [AUTH::last_event_session_id])} {
log local0. “$tmm_auth_ssl_crldp_sid”
array set auth_response_data [AUTH::response_data]
log local0. “Array auth_data has [array size auth_response_data] elements.”
foreach value [array names auth_response_data] {
log local0. “$value”
set tmm_auth_status [AUTH::status]
if {$tmm_auth_status == 0} {
log local0. “Authorization success!”
SSL::handshake resume
} elseif {
$tmm_auth_status != -1 || $tmm_auth_ssl_crldp_done == 0} {
log local0. “Authorization failure.” reject
Thnaks,
Mitch
Hi Mitch,
What do you see in the logs for the AUTH::response_data logging?
Which LTM version are you testing on?
Is auth against the CRLDP service working?
Aaron
Thanks for the response hoolio. Nothing gets returned from AUTH::response. However, I can get an AUT::status returned. I am testing against BIG-IP 10.1.0 Build 3341.0 Final. I saw some other posts that cliamed AUTH::response_data has been broke since 10.0. I don’t know if that is true.
I don’t think AUTH::response_data is expected to return anything if the authentication attempt fails. Are you seeing it return nothing when auth succeeds?
Aaron
Yes. AUTH::success returns 0 when it is successful and returns 1 when unsuccessful.
BTW, does anyone know wht the Cache Timeout entry in the Authentication configuration object is for? It’s not in the manual or help.
BTW, does anyone know wht the Cache Timeout entry in the Authentication configuration object is for when using CRLDP? It’s not in the manual or help.
It appears that default_ssl_crldp does not return anything via the AUTH::response as does cc_ssl_ldap. However, since AUTH::success is resturned, where does this show up in the pam audit log?
