ASM block settings for IBM Maximo
Hello Experts
I need to enable ASM for IBM Maximo application. What block settings (like illegal meta value in character, illegal http response code etc) under policy → block settings, should I need to enable (at least)? Is there any deployment guide available? I am doing manual policy configuration
Regards,
There is no Application-Ready-Template for IBM Maximo and no deployment guide. You will need to start from the Rapid Deployment Policy and build the policy in Transparent (non-blocking mode) to learn the application.
Yes, you always have an option to build a policy automatically by learning traffic. It works best if you can identify trusted traffic (.e.g based on IP address/subnet)
Here is the documentation:
Hope this helps,
Sam
