Hello, We enabled asm provisioning our environment and not having much expertise in this. I need your expertise for the same. anyone help us to build better policy for securing applications
Hi @tiwi_f
i suggesting to understood ASM from any devcentral videos or any f5 articles first. As you are a beginner, please start with rapid deployment policy.
Please let me know any other queries you have.
BR
Aswin
Could you please provide me article about this and explain about the mentioned rapid deployment policy
Please use this article - ASM operation guide - myF5
i suggested rapid deployment policy because, it will not block anything by default. You can set policy reediness period and within time you will get traffic learning details from F5 GUI .The Rapid Deployment security policy provides security features that minimize the number of false positive alarms and reduce the complexity and length of the deployment period.
Please go through below link to understand more about rapid deployment - https://techdocs.f5.com/kb/en-us/products/big-ip_asm/manuals/product/asm-getting-started-12-1-0/7.html#:~:text=The%20Rapid%20Deployment%20security%20policy,Performs%20HTTP%20compliance%20checks
Also , Please verify if your F5 have enough memory for ASM operations. Once you set ASM it will also consume CPU and memory.
BR
Aswin
Thanks for the explanation, let me go through it @Aswin_mk
