APM doesn’t expose any detail about the SAML SP Issuer when authentication requests hitting APM as an IdP during an SP initiated SAMLRequest. This iRule when applied to a SAML IdP enabled virtual server will extract the assertion request, decode it and present the SAML SP Issuer ID as the session variable %{session.saml.request.issuer} within APM.
How to use this snippet:
This comes in real handy when performing authorisation of the resource and could help avoid having APM perform a TCP connection reset when a SAML resource isn’t authorised.
Code :
when CLIENT_ACCEPTED {
ACCESS::restrict_irule_events disable
if { [HTTP::path] equals "/saml/idp/profile/redirectorpost/sso" } {
if { [HTTP::method] equals "POST" } {
# Colelct POST data
set content_length [HTTP::header value Content-Length]
HTTP::collect $content_length
} elseif { [HTTP::method] equals "GET" } {
#TODO
when HTTP_REQUEST_DATA {
set payload_data [URI::decode [HTTP::payload]]
log local0. "payload=[URI::query "?$payload_data" "SAMLRequest"]"
if { $payload_data contains "SAMLRequest" } {
# Extract SAML request data
set SAMLdata [b64decode [URI::query "?$payload_data" "SAMLRequest"]]
set SAML_Issuer_loc [string first "saml:issuer" [string tolower $SAMLdata]]
set SAML_Issuer_start [expr {[string first ">" $SAMLdata $SAML_Issuer_loc] + 1}]
set SAML_Issuer_end [expr {[string first "<" $SAMLdata $SAML_Issuer_start] - 1}]
set SAML_Issuer [string range $SAMLdata $SAML_Issuer_start $SAML_Issuer_end]
if { !([ACCESS::session sid] equals "" ) } {
ACCESS::session data set session.saml.request.issuer $SAML_Issuer
when ACCESS_SESSION_STARTED {
if { [info exists SAML_Issuer] } {
What do you mean? Redirect Binding? Just try to fetch the Request by extracting the URL parameter using HTTP::query i.e. There are a bunch of examples for extracting URL parameters on DevCentral.
Did someone ever figured out the part with the GET part, where the SSO SAML is initiated with a HTTP GET?
Also has someone got an idea, once the response is signed, how can we see this content? even with SAML-Tracer I’m not able to decode the base64encoded SAMLRequest string to something readable, but the tool itself can read the SAMLRequest.
As SAML Requests can be signed, is there a posibility to verify its signature before the APM policy finishes?
I want to change the logic flow in the APM Policy of the IdP depending on the SAML issuer, but fear that it can be manipulated by an attacker, allowing altering the IdP behaviour in an unintended way.
