APM - Portal access - Issue
Hi Guys,
I got the issue with formatting styling of web page.
In web tools I see the deny. Someone can support to fix that case.
Best regards
I took some screenshots describing the login process up to the blank page. If that can give an idea of how it behaves.
I got this error
Can I bypass them ?
Hello @ASCapi
I noticed there was no response on your post, if you have any update I would like to encourage you to provide that. If you don’t have an update, we can see what options you may have for support to assist you.
-Melissa
Hi @Melissa_C
I haven’t found a way to work around this issue yet. We’re still testing and looking for a solution to resolve this issue.
ASCapi
If you haven’t done a case with our support team yet I can see if that would be a resource that could assist you. You can send me a direct message with your device serial number and software version if you would like and I can check if that would be available. Or you can visit MyF5 to create a case if you know you have support.
-Melissa
Hi @ASCapi ,
Did you resolve this? If not, your best bet is to open a support case and upload your captures and I can check it out and provide a solution.
-Seth
