APM logon customization
Hi all,
Would someone be able to help me with customizing the APM logon page to something like the below picture.
I have an HTML code for my display but struggling to understand the format of the APM_FILL.CSS file where these settings are stored.
Is there a section in there that is dedicated for HTML or does it require another language?
Any guidance is appreciated.
Admin update: adding image inline for simplicity
bump…
So you need just to create a line after Logon button with a link?
If thats the case, you could go to:  Access  ››  Profiles / Policies : Customization : Advanced
Select your policy
select you Logn Page
and modify user-logon.js
check this links also
APM Advanced Customization Examples with Modern Template, v15.1+ | DevCentral
