5 Technical Sessions That Should Be Great: F5 AppWorld 2025
These F5 Academy sessions explore modern app delivery, security, and operations.
The full list of sessions is on the F5 AppWorld 2025 Academy page - if you haven’t yet registered you can do so here: Register for F5 AppWorld 2025
LAB - F5 Distributed Cloud: Discovering & Securing APIs
API security has never been more critical, and this lab dives straight into the tough stuff. Learn how to find hidden endpoints, detect sensitive data and authentication states, and apply integrated API security measures to keep your environment locked tight.
TECHNICAL BRIEFING - LLM Security and Delivery with F5’s Distributed Cloud Security Ecosystem
AI is fueling the next wave of applications—but it’s also introducing new security blind spots. This briefing explores how to secure LLMs and integrate the right solutions to ensure your AI-driven workloads remain fast, cost-effective, and protected.
LAB - F5 NGINX Plus Ingress as an API Gateway for Kubernetes
Containerized environments and microservices are here to stay, and this lab helps you navigate the complexity. Configure NGINX Plus Ingress as a powerful API gateway for your Kubernetes workloads, enabling schema enforcement, authorization, and rate-limiting all in one streamlined solution.
LAB - Zero Trust at Scale With F5 NGINX
Zero trust principles become a whole lot more meaningful when you can scale them. Get hands-on with NGINX Plus and BIG-IP GTM to build a robust, scalable zero trust architecture, ensuring secure and seamless app access across enterprises and multi-cluster Kubernetes environments.
LAB - F5 Distributed Cloud: Security Automation & Zero Day Mitigation
In this lab, you’ll learn how to leverage advanced matching criteria and custom rules to quickly respond to emerging threats. Shore up your defenses with automated policies that deliver frictionless security and agile zero-day mitigation.
Session Updates Coming in January :police_car_light:
AppWorld’s Breakout Sessions officially drop in January 2025 but here is a sneak preview!
Check back in January to add these to your agenda.
  • Global App Delivery With a Global Network
  • How Generative AI Breaks Traditional Application Security and What You Can Do About It
  • The New Wave of Bots: A Deep Dive into Residential IP Proxy Networks
  • From ZTNA to Universal ZTNA: Expanding Your App Security Strategy
See you at F5 AppWorld 2025!
#AppWorld25
