Timing is a command in iRules that triggers the system to track the number of cycles each event in an iRule consumes. Deb has covered timing previously in iRules Optimization 101 #05 – Evaluating iRule Performance, so I took that and a presentation someone internally put together from that information and recorded a walkthrough on what makes timing tick. (ba-dah, ching!)
I also took the opportunity to dust off my pycontrol skills and whipped up a script that will do some load testing against a virtual with your iRule applied, then download and crunch the stats specific to your platform cores/speeds so the numbers should be accurate.
I uploaded the script to the iControl codeshare, titled pycontroliRuleTiming. A sample of the output from the script is below:
jrahm@jrahm-dev:/var/tmp$ ./iRuleStats.py 10.10.20.5 admin timing_test http://10.10.20.50
Please enter your password:
Password:Resetting Statistics for the timing_test iRule
Running load test to host http://10.10.20.50
### Raw Data ###
Event: HTTP_REQUEST
STATISTIC_RULE_AVERAGE_CYCLES = 41767
Event: HTTP_RESPONSE
STATISTIC_RULE_AVERAGE_CYCLES = 92363### iRule timing_test Performance Results
BIG-IP LTM 3600 has 3413568000 availabe CPU Cycles (2 cores, 2133.480 MHz)
Average Cycles/sec: 134130
CPU Utilization/req: 0.00392931970302 percent
Max Requests/sec: 25449
Happy coding!
Related Articles
- Timing iRules - DevCentral - F5 DevCentral > Community > Group …
- irule timing: how to convert Cycles to Seconds - DevCentral - F5 …
- iRules Optimization 101 #05 - Evaluating iRule Performance …
- Time-based iRules - DevCentral - F5 DevCentral > Community > Group …
- When Optimization Techniques Fail -- Why Testing is so Important
- Perfomance gain of using HTTP Classes over iRules - DevCentral …
- iRule causing ever-increasing TMM CPU utilization - DevCentral …
- iRules 101 #06 - When > DevCentral > F5 DevCentral > Tech Tips
