Hi, hoping someone has a simple answer. Have a portal defined running Edge Gateway 11.2.1 HF3.
When launching the RDP client on Mac (mountain lion) the client launches however the keyboard will not respond. Mouse and graphics work, but can’t use keyboard…
On an XP machine the java client doesn’t launch at all. Has anyone else had this issue or am I alone with this. ?
RDP config is bog standard, so not sure where this would have gone astray.
Have raised a ticket with F5 support but thought I’d try my luck here in the interim.
We are having problems with Java RDP client and that version.
In our case, the Java RDP connection works fine with Windows XP and Windows 7, but we get an exception message if we use MAC or Windows 8 altough Java version is the same in all cases.
Our ticket has been open for sereval weeks but there’s still no solution.
I’ve had a ticket open with F5 for a while (And F5 have now opened a ticket with oracle too about the bug). The bug itself hasn’t had any action for about 6 months now (14/12/2012).
That’s the bad news. The GOOD news is that it’s simply because the Mac can’t resolve it’s own hostname to an IP. usually this is because you’re on a public WLAN or similar and there’s no DNS entry for whatever the FQDN is of your MAC. The even BETTER newws is that although the java RDP client REQUIRES to be able to do the lookup, IT NEVER USES the result.
So you can work-around the problem just by inserting an alias into your /etc/hosts file for the loopback. (i.e. Put the FQDN of the mac at the end of the line that starts with 127.0.0.1
