X-Forwarded-For HTTP Module For IIS7, Source Included!
For those who of you that are having problems with logging client addresses in their server logs because you are running your web servers behind a proxy of some sort, never fear, your solution i...
Published Dec 23, 2009
Version 1.0spellingb
Sep 13, 2019Hey i'm having the exact same issue. I tried installing for IIS 10 but get error
"The specified procedure could not be found." with a detailed error of 0000007F - "The specified procedure could not be found." discussed here https://blogs.msdn.microsoft.com/david.wang/2005/06/21/howto-diagnose-and-fix-common-isapi-filter-installation-failures/
From what I can tell, there looks to be something that needs updated in the DLL for IIS 10
any info on how to get this working in IIS 10 would be wonderful!!!
