X-Forwarded-For HTTP Module For IIS7, Source Included!
For those who of you that are having problems with logging client addresses in their server logs because you are running your web servers behind a proxy of some sort, never fear, your solution i...
Published Dec 23, 2009
Version 1.0Kyle74
Altocumulus
Jul 30, 2019Hi Joe,
So we're having to use this in IIS 10 on Server 2016.
Our security team doesn't like the XFF and C-IP being separate, so I've been tasked with finding a way to merge the two, this looks like the answer.
However, on a test server, I'm not sure how to test this out and make sure it works.
I do have a custom log for the XFF field setup, not sure if that's messing with the module.
The server I'm working on is not behind the F5 and I can only connect to the host internally, though I'm using Fiddler to setup a proxy.
I'm not sure if the module is working or not.
Could you assist?
