X-Forwarded-For HTTP Module For IIS7, Source Included!
For those who of you that are having problems with logging client addresses in their server logs because you are running your web servers behind a proxy of some sort, never fear, your solution i...
Published Dec 23, 2009
Version 1.0josh_wiss_16008
Jun 06, 2014I have came across an odd issue with the module.
First i enabled X-forwarded on the F5
then i enabled Snat pool
then i installed the Module on an iis 7 build
When i get 200, 302, 500 responce the Client ip is listed correctly.
when i get a 400 responce the client ip shows up as the SNAT ip.
i installed netmon and the Xforwarded address is there and correct but it is not making it to the IIS logs.
