X-Forwarded-For HTTP Module For IIS7, Source Included!
For those who of you that are having problems with logging client addresses in their server logs because you are running your web servers behind a proxy of some sort, never fear, your solution i...
Published Dec 23, 2009
Version 1.0JRahm
Admin
Apr 01, 2011Does this only modify the X-Forwarded-For header that is stored in the IIS logs? Or if I use Request.ServerVariables["X-Forwarded-For"], will I also see the new value? What if the request is over SSL?
