VMware Fusion Custom Networking for BIG-IP VE Lab
Hi Jason,
Thanks for the pointers here and that's a great article. However, just wanted to give a quick update here since there were a couple of changes since MacOS BigSur and VMware Fusion updates.
The edit on /Library/Preferences/Vmware\ Fusion/networking remains the same and thanks for that.
However, on top of that I had to manually create "/Library/Preferences/VMware\ Fusion/vmnetX" folder (where X is the vmnet number you picked) for each vmnet added to "networking" config above. I also copied the "dhcpd.conf" from "vmnet1" as template and edited it and changed the addresses accordingly.
The "vmnet" interfaces no longer magically appear like in your example above. I had to type this command:
$ sudo /Applications/VMware\ Fusion.app/Contents/Library/vmnet-cli --stop
$ sudo /Applications/VMware\ Fusion.app/Contents/Library/vmnet-cli --startAnd then I was able to select the vmnetX interfaces I created.
