Using VPC Endpoints with Cloud Failover Extension
Introduction
Have you heard of the new F5 Cloud Failover Extension? Well if you haven’t, I encourage you to go out and read about this new feature. CFE is an iControl LX extension that provides L3...
Published Apr 27, 2020
Version 1.0Noof
Employee
Solutions Architect currently covering the public sector.TJ_Vreugdenhil
Cirrus
May 05, 2020Hey - Thanks
I just opened an issue at Github.
The setup is an F5 HA Pair in the same AZ. HA Configsync/Failover is working over internal NIC. However there is 2 NICS for internal, and 1 NIC for external, both acting as reverse proxies, so all three NICS are added to the declaration. Yes I created both the S3 gateway endpoint and S3 endpoint as indicated in this article. I will look at the S3 bucket - It does have the proper tag matching the declaration. Here is the "f5cloudfailoverstate.json" in the F5 S3 bucket:
{"taskState":"FAILED","message":"Failover failed because Recovery operations are empty, advise reset via the API","timestamp":"2020-05-05T17:03:39.568Z","instance":"ip-10-10-8-10.us-east-2.compute.internal","failoverOperations":{"addresses":null,"routes":null}}
