Using VPC Endpoints with Cloud Failover Extension
Introduction
Have you heard of the new F5 Cloud Failover Extension? Well if you haven’t, I encourage you to go out and read about this new feature. CFE is an iControl LX extension that provides L3...
Published Apr 27, 2020
Version 1.0Noof
Employee
Solutions Architect currently covering the public sector.Noof
Employee
May 05, 2020Hello TJ,
You may want to open an issue at Github. I have yet to see this error.
https://github.com/F5Networks/f5-cloud-failover-extension/issues
What does your BIG-IP setup look like? HA across net or same net?
Did you setup the S3 gateway endpoint?
It is not happy about the recovery being empty. Do you have state in your S3 bucket? It should have backup folder and others.
Error: Recovery operations are empty, advise reset via the API
