Troubleshooting TLS Problems With ssldump
Introduction
Transport Layer Security (TLS) is used to secure network communications between two hosts. TLS largely replaced SSL (Secure Sockets Layer) starting in 1999, but many browsers still pr...
Published Oct 14, 2010
Version 1.0George_Watkins_
Historic F5 Account
lossless_186906
Jul 08, 2018Hi Ajit,
If you look closer the S>C is part of a different TCP connection (3), whereas initial C>S is 7. Maybe some asymmetric routing, missing SNAT?
Might be worth enabling ssl debugging and checking the logs: modify /sys db log.ssl.level value Debug
Cheers, Mariusz
