Site Launch Frequently Asked Questions
Hey there, community. We are maintaining this FAQ as new issues come in that might be experienced by the community at large. This will be continually updated as we fix the discovered issues.
Login...
Published May 17, 2019
Version 1.0Chase_Abbott
Admin
I do stuff.Chase_Abbott
Admin
May 28, 2019
Download and install PowerShell from Microsoft
Go to the PowerShell Labs page on DevCentral and select the "Download Now" link. This will download the Cmdlet installer.
Run the iControlSnapInSetup.msi installer. This will install the SnapIn into the c:\program files\F5 Networks\iControlSnapIn directory.
Start PowerShell from the Windows Start menu.
Cd to c:\program files\F5 Networks\iControlSnapIn directory
Dot Source the setup script (only once after the install)
PS > . .\setupSnapIn.ps1)
Load the SnapIn into the Runtime
PS > Add-PSSnapIn iControlSnapIn
Initialize the iControl connection with the Initialize-F5.iControl CmdLet
PS > Initialize-F5.iControl -Hostname bigip_address -Credentials (Get-Credential)
Run the Get-F5.iControlCommands CmdLet to list out all the available Cmdlets.
PS > Get-F5.iControlCommands
Try out some of the CmdLets
PS > Get-F5.LTMPoolhttps://cdn.f5.com/websites/devcentral.f5.com/downloads/f5-icontrol-powershell-snapin-13_1_0.zip
