Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
ahmed91_235350
Sep 24, 2018Worked fine for me .. thanks for this amazing effort
as a recap (I work on Windows)
- export nessus file - change the extension to xml, remove anything between and
- download the https://github.com/Mikej81/f5-asm-generic/blob/master/nessus/nessus2asm.xsl -- don't change anything
- download https://www.microsoft.com/en-us/download/details.aspx?id=21714, unzip to any partition and copy both xml/xsl files to the same folder
cd to path of the folder then run the following command !!consider change name between [ ]
msxsl [outputfromnessus].xml [formdownloadedfromgithub].xsl -o [outputtonessus].xml - take the output file and import it to nessus
again amazing work from you Michael J F5
