Was this article helpful?
hello Michael ,
please correct me if im woring
1) downloaded nessus2asm.xsl
2) downloaded Nessus scan
3) i used the /
4) Generic Scanner : import > (Vulnerabilities file doesn't contain Vulnerabilities Found And Verified By Generic Scanner)
scanner_vulnerabilities xmlns:foo="http://www.foo.org/"; xmlns:bar="' target="_blank" rel="nofollow">http://www.bar.org">; Other Application Attacks Nessus Scan Information Information about this scan :
Nessus version : 7.0.1 Plugin feed version : 201801180515 Scanner edition used : Nessus Scan type : Normal Scan policy used : HQ scan Scanner IP : 192.168.168.200 Port scanner(s) : wmi_netstat Port range : 1-65535 Thorough tests : yes Experimental tests : no Paranoia level : 1 Report verbosity : 1 Safe checks : yes Optimize the test : yes
