Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Mohanad
Mar 05, 2018I Have scanned the server and download the report ext .nessus and renamed it to .xml and tried to convert from XML to XSL but I couldn't use the online tools gives me errors, then I have downloaded msxsl.exe but I don't know the command to convert, I googled it but no luck with me, can anyone tell what is the command to convert the file? thank you so much
