Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
Killian_Chopine
Oct 12, 2017Thanks you, it's working perfectly now. I removed the "disable-output-escaping=yes" part and I was able to import inside BigIP !
