Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
Killian_Chopine
Oct 12, 2017Yeah, I'm using the most recent XSL posted on github. I've tried the sample scan result from DVWA and it's working. I'll take a look inside the scan result and try to find a character that might be causing an issue.
