Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
MichaelatF5
Employee
Oct 12, 2017Killian, are you using the most recent XSL posted on github? I also included a sample scan result from DVWA, and the output file.
Its possible there may be a character that is causing an escape issue. If we can find what it is we can add an option to ignore escapes or we can look at replacing the string.
