Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
MichaelatF5
Employee
Sep 27, 2017Explain what you are doing...
You ran Nessus and exported the result in Nessus format? Which version of Nessus are you running?
You renamed the Nessus file to XML?
You downloaded the XSLT and ran it against the renamed Nessus xml?
Post a sample of the output so we can see what it looks like.
