Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
MichaelatF5
Employee
Sep 26, 2017Some character encoding may have gotten messed up on the post. Did you download the XSLT from github and try that?
Also, which version of TMOS are you running?
