Nessus 6 XSLT Conversion for ASM Generic Scanner Import
It is important to understand while reading this, I am not an ASM SME...
The goal was to create a simple conversion of the Nessus Vulnerability Scan reports to import into ASM. The first step was ...
Published Sep 11, 2017
Version 1.0MichaelatF5
Employee
Joined January 25, 2011
Harry1
Sep 26, 2017Hi Michael,
do I need to edit something in imported ASM generic scanner file which is in .xsd extension? because when I am merging both file([root@f5labv13:Active:Standalone] tmp xsltproc generic_scanner.xsd Main_Authenticated_Vulnerability_Scan_sr4pxu.nessus >ASM_Import1.xml , generic scanner and Nessus xml, getting error like: compilation error: file generic_scanner.xsd line 2 element schema )
