Meltdown and Spectre Web Application Risk Management
The recently disclosed groundbreaking vulnerabilities have set a precedent for how massive a security vulnerability can be. In the recent years, we have witnessed vulnerabilities that affect major fr...
Updated Jun 23, 2022
Version 2.0Nir_Zigler_7297
Historic F5 Account
Nir_Zigler
Employee
Avalanchee
Nov 01, 2018Unfortunately the HTTP::Cookie command doesn't support the SameSite flag. If support was to be added, it would be included in versions past 13.1.0 - which would make it obsolete for the issue at hand (since this feature is included in ASM since 13.1.0).
The best way to have this enabled using an iRule would be to rewrite the Cookie header using string search and replace.
You would have to capture responses from the web server, search for the following header: "Set-Cookie: my_cookie=abcd;" and rewrite it as: "Set-Cookie: my_cookie=abcd; SameSite=Lax"
