iRule to set SameSite for compatible clients and remove it for incompatible clients (LTM|ASM|APM)
A bunch of us have been refining approaches to help customers handle the new browser enforcement of the HTTP cookie SameSite attribute. I think we have a pretty solid approach now to handle compatib...
Published Feb 10, 2020
Version 1.0Aaron_Hooley
Ret. Employee
Joined February 06, 2020
Aaron_Hooley
Jan 04, 2021Ret. Employee
Hi and ,
Do you have APM enabled on the virtual server? Or another iRule that is sending an HTTP response?
I believe the issue is described in K23237429:
K23237429: TCL error: ERR_NOT_SUPPORTED after upgrade to version 14.1.0 or later
https://support.f5.com/csp/article/K23237429
Once I understand the configuration that's causing the TCL error, I can try to suggest a fix for it.
Thanks, Aaron
