iRule to set SameSite for compatible clients and remove it for incompatible clients (LTM|ASM|APM)
A bunch of us have been refining approaches to help customers handle the new browser enforcement of the HTTP cookie SameSite attribute. I think we have a pretty solid approach now to handle compatib...
Published Feb 10, 2020
Version 1.0Aaron_Hooley
Ret. Employee
David_Scott
Employee
Feb 16, 2020if you're on a version that doesn't support the HTTP::cookie attribute method (v11 mainly) here's a way to add the attribute it. Ideally you'd upgrade to v12+ but if that's not an option it does add the attribute. Obviously change SameSitee=none to
when HTTP_RESPONSE {
set COOKIE_VAL [HTTP::header values "Set-Cookie"]
HTTP::header remove "Set-Cookie"
foreach COOKIE_NAME $COOKIE_VAL {
HTTP::header insert "Set-Cookie" "${COOKIE_NAME}; SameSite=none"
HTTP::cookie secure ${COOKIE_NAME} enable
}the above and this could probably be integrated together for older versions until they can upgrade.
