Jun 26, 2008
Right now, all it does is look for an incoming X-Forwarded-For HTTP header. If it's found, the value in it is used for the c-ip value in the IIS access logs. I'm sure you could write a filter that does what you propose, or take the source from the XFF filter and tailor it to your needs, but this one doesn't do what you are asking.
-Joe
