How I did it - "Visualizing Data with F5 TS and Splunk"
The new Splunk Add-on for F5 BIG-IP includes several objects, (modular inputs, CIM-knowledge, etc.) that work to “normalize” incoming BIG-IP data for use with other Splunk apps, such as Splunk Enterp...
Updated Dec 13, 2022
Version 2.0Greg_Coward
Employee
Joined July 19, 2011
Greg_Coward
Employee
Sep 05, 2023Hello @abyanfaishal
I believe the command to fix as noted in the article you mentioned - https://my.f5.com/manage/s/article/K05413010 (see command below) will address the issue. Unfortunately, I don't know of a way to avoid the allowing loopback address.
Command - tmsh modify sys db tmm.tcl.rule.node.allow_loopback_addresses value true
tmsh save sys config
Thanks,
Greg
