How I did it - "Visualizing Data with F5 TS and Splunk"
The new Splunk Add-on for F5 BIG-IP includes several objects, (modular inputs, CIM-knowledge, etc.) that work to “normalize” incoming BIG-IP data for use with other Splunk apps, such as Splunk Enterp...
Updated Dec 13, 2022
Version 2.0Greg_Coward
Employee
Joined July 19, 2011
abyanfaishal
Sep 05, 2023i found the root cause already, There is a functional code change in 15.1.6.1 and up, that blocking iRule using node and loopback IP based on https://my.f5.com/manage/s/article/K05413010, i know it earlier but i still didnt have guts since it will open me to a vulnerability, do you guys have any chance to help me to fix or to find another way around to get similar result as the iRule?
the iRule is
ltm rule telemetry_local_rule {
when CLIENT_ACCEPTED {
node 127.0.0.1 6514
Thankyou
