How I did it - "Visualizing Data with F5 TS and Splunk"
The new Splunk Add-on for F5 BIG-IP includes several objects, (modular inputs, CIM-knowledge, etc.) that work to “normalize” incoming BIG-IP data for use with other Splunk apps, such as Splunk Enterp...
Updated Dec 13, 2022
Version 2.0Greg_Coward
Employee
Joined July 19, 2011
MichaelOLeary
Employee
Apr 10, 2023Greg_Coward and WildWeasel, one thing I find it worth pointing out is that the TMSH command above includes the name of the VIP "/Common/Shared/telemetry_publisher" - however, in my case I have set this up before without using AS3, so the VIP name was "/Common/telemetry_publisher" (or, whatever I may have used instead of telemetry_publisher). So, you may need to edit that TMSH command accordingly.
I make this point in case you copy/paste the TMSH command to export AVR stats and your VIP name is not the same as Greg's. I made this mistake myself and it took me a while to realize it 😀
