How I did it - "Visualizing Data with F5 TS and Splunk"
The new Splunk Add-on for F5 BIG-IP includes several objects, (modular inputs, CIM-knowledge, etc.) that work to “normalize” incoming BIG-IP data for use with other Splunk apps, such as Splunk Enterp...
Updated Dec 13, 2022
Version 2.0Greg_Coward
Employee
Joined July 19, 2011
Greg_Coward
Employee
Apr 06, 2023Hello,
For AVR, you need to apply a TMSH command to point the AVR configuration to the log publisher. The specific TMSH command is - modify analytics global-settings { external-logging-publisher /Common/Shared/telemetry_publisher offbox-protocol hsl use-offbox enabled }. You can find additional information related to this at: https://clouddocs.f5.com/products/extensions/f5-telemetry-streaming/latest/avr.html#modifying-avr-configuration-to-use-the-log-publisher
Hope this helps,
Greg
