How I did it - "Visualizing Data with F5 TS and Splunk"
The new Splunk Add-on for F5 BIG-IP includes several objects, (modular inputs, CIM-knowledge, etc.) that work to “normalize” incoming BIG-IP data for use with other Splunk apps, such as Splunk Enterp...
Updated Dec 13, 2022
Version 2.0Greg_Coward
Employee
Joined July 19, 2011
Greg_Coward
Employee
Nov 08, 2021Hello Joe,
There is a TMSH command required to enable AVR. Run this on your BIG-IP(s) - tmsh modify analytics global-settings { external-logging-publisher /Common/Shared/telemetry_publisher offbox-protocol hsl use-offbox enabled }.
You can modify the AS3 declaration to create resources in a different partition if necessary. With that said, the resources are deployed as 'Shared' under the Common partition. You should be able to view and attach them to your virtual(s). Note: If you do use a different partition, you will need to adjust the above TMSH command accordingly.
