Building an OpenSSL Certificate Authority - Configuring CRL and OCSP
Certificate Revocation Lists
We completed reviewing our PKI design considerations and created root and intermediary certificates completeing our two-tier certificate authority. Now we'll create ce...
Updated Jun 05, 2023
Version 2.0Chase_Abbott
Admin
I do stuff.RWood_383320
Feb 08, 2019When you create the OCSP key & certificate, your sample code uses the openssl_server.cnf (which you don't introduce until the next article) but when you sign the certificate you use the openssl_intermediate.cnf.
Does it matter if you switch between the two? Is there that much difference between the two config files?
