BIG-IP Next Automation: AS3 Basics
If using the compatibility API re-POSTing the declaration should work to make an update. If using the documents API, you need to send a PUT to make an update.
In Next, an HA cluster is regarded as a single instance functionally, so you would target the management plane floating IP address.
Management floating IP - great! I should really setup a Next cluster to get more familiar with it.
Ok, I used the new API. Is the compatibility API came to stay? Or should it be used only for easier transistions? I thought it is more future proof to use the new API's.
