Substitute - a simple iRule script to simulate apache mod_substitute
Problem this snippet solves:
Sometimes it is neccessary to rewrite some stuff in delivered HTTP-Content. Here we have a simple way to search an replace these thinks.
How to use this snippet:
If you want to use these script you have to provide a data group with type string named
Substitude_<VS>
Here each line have the format
ul
Code :
when RULE_INIT {
# Enable to debug Substitute translations via log messages in /var/log/ltm
# (2 = verbose, 1 = essential, 0 = none)
set static::SubstituteDebug 0
set static::log_prefix "[IP::client_addr]:[TCP::local_port]:"
# Disable the stream filter for all requests
STREAM::disable
# The name of the Data Group (aka class) we are going to use.
# Parse just the virtual server name by stripping off the folders (if present)
set class_name "Substitute_[URI::basename [virtual name]]"
if { $static::SubstituteDebug > 1 } {
log local0. "$static::log_prefix [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port]"
when HTTP_RESPONSE {
# disable stream by default
STREAM::disable
if { $static::SubstituteDebug > 1}{
log local0. "$static::log_prefix: disable stream per default"
# Create all essential variables for the logic below
# set all variables to an empty value
set regexreplace ""
set regex ""
set replace ""
# Check whether class_name exist or not.
# If it doesn't exists log an that the data group is missing an exiting
if {! [class exists $class_name]} {
log local0. "$log_prefix: Data group $class_name not found, exiting."
return
# Here we know that the needed data group exists and we can go on
# set id for iteration purpose
set id [class startsearch $class_name]
# iterate over data group list to get all regex replace pairs
while {[class anymore $class_name $id]}{
# save actual line of data group in element
# extract regex and replace from element
set element [class nextelement $class_name $id]
set regex [getfield $element " " 1]
set replace [getfield $element " " 2 ]
if { $static::SubstituteDebug > 1} {
log local0. "$log_prefix: regex=$regex, replace=$replace"
# and build a string with all regex replace pairs
set regexreplace "@$regex@$replace@ $regexreplace"
log local0. "$log_prefix: regexreplace=$regexreplace"
# if regexreplace is set
if {$regexreplace ne ""}{
# and content-type equals text
if {[HTTP::header value Content-Type] contains "text"}{
log local0. "$log_prefix: try STREAM::expression [string trim $regexreplace " "]"
# apply regexreplace pairs to stream
log local0. "$log_prefix: enable stream"
# Enable the stream filter for this response only
STREAM::enable
}Tested this on version:
11.5Updated Jun 05, 2023
Version 2.0Christian_Meiss
Joined May 05, 2019
