Split records across many subtables for better distribution across TMMs
Problem this snippet solves:
This iRule demonstrates how to use multiple subtables to distribute session table entries. As a subtable is pinned to a specific TMM, using multiple subtables distributes the load more evenly across TMMs. We use CRC32 hashing of the key being stored to deterministically pick the subtable name to store a key in.
Code :
when RULE_INIT {
# Number of subtables to create (should be ~3+ x TMM count). Use 100 as a test.
set static::subtable_count 100
# Time to save subtable entries for
set static::lifetime 3600
# Prefix to keep these subtable names unique from other iRules
set static::prefix "mysubs"
when CLIENT_ACCEPTED {
# Pick some unique key for the subtable entries
set key [TCP::client_port]
# Look up the key in the subtable this key should be crc32 hashed to and save the value
set value [table lookup -subtable "${static::prefix}_[expr {[crc32 $key] % $static::subtable_count}]" $key]
log local0. "Looked up $key in ${static::prefix}_[expr {[crc32 $key] % $static::subtable_count}] subtable and found \"$value\""
# Check if there was a value for the given key
if {$value eq ""}{
# No value so add the key and value to the subtable determined by the crc32 hash of the key
table set -subtable "${static::prefix}_[expr {[crc32 $key] % $static::subtable_count}]" $key "some value" indef $static::lifetime
# Do something with the stored value for this key
}Published Mar 18, 2015
Version 1.0hoolio
VP of Solutions at WorldTech IThoolio
VP of Solutions at WorldTech ITNo CommentsBe the first to comment
